Author Topic: Changing boost with a smaller crank pulley  (Read 2840 times)
juan
  • Guest
« on: December 17, 2008, 06:03:09 pm »
As above, im wondering if anyone knows much about changing boost by varying the size of the crank pulley?
Is this a stupid idea? are there any problems i might encounter? (I know it will affect how fast the alternator spins but the alternator pulley could be changed accordingly)
Re: Changing boost with a smaller crank pulley
« Reply #1 on: December 17, 2008, 06:41:45 pm »
reducing the crank pulley will decrease the rpm of the charger.  I believe the PSD toothed belt kits actually include a slightly larger than stock crank pulley which combined with the charger pulley they supplied gives the equivalent rpm as having a stock crank pulley size and 65mm charger pulley.  I believe the reason for this is that making the toothed charger pulley any smaller would mean not enough teeth on the belt mesh.
what are you trying to achieve?
juan
  • Guest
« Reply #2 on: December 17, 2008, 06:56:38 pm »
Its for the pulley system on the eaton, as i was thinking of doing a two part pulley but it turns out this would require a fair bit of work :(
I think ive realised what to do now, but thanks for the info :)
