Brake Servo Reservoir
Started by Matty!, April 17, 2014, 09:49:04 AM
Matty!
Hey Guys
After fitting my strut brace my Brake Reservoir seems to be fouling the strut brace, making it lean back, it works fine but I dont fancy really running it too much knowing about this.
Before I end up draining my system for no reason has anybody had this problem before and ither modified, rotated or retrofitted to get around this?
Matty
Matty!
Also it has the upgraded servo on it apparently.
breadman
Matty, as far as I'm aware there isn't an "upgraded" servo available for the RHD 2F Polo.
I think the after market upper strut braces tend to be hit and miss when it comes to fitment, hence the interference with the reservoir.
I think I'd sooner run without one, they don't do much on these Polo's anyway.
Sure you dont mean upgraded master cylinder?
on some i beleive you can turn the reservoir 180 degrees to stop it fouling
Fred's mk2 polo it turned 180.
Matty!
master cylinder yes sorry!
and cool ill try the 180" first.
cheers again chaps!
