you assemble the counter shaft into one unit with bearings and weight etc. then pop in freezer. When you heat the casings up you pop the centre bearing and counter shaft in. they just drop in. Easier than bearing, woodruff key, counterweight, bearing and going in the countershaft hole.
I cleaned the external part of mine with petrol as a degreaser and then used hi -temp paint. doesn't need to be ultra hi temp though.
if you need to give me a bell, please do. Also if cutting apex seals, make sure they are slightly longer and then kindof force them into the hole... so there is absolutely no forwards/backwards movement, or this can wear the apex seal walls.
pete
