Rad fan switch
Started by CJ Dubs, March 19, 2014, 06:23:29 PM
CJ Dubs
Guys,
Anyone know what the red/black wire on the rad fan switch goes to?  I'm putting a new loom in mine but this wire has been cut and I cannot see the other end! >:(
There are three wires on the rad fan switch - red/black, red/white & red/brown.
Pics below:
Cheers,
Chris.
physicsfool
It attaches into the other fan switch!
It's the fat black plug that also has a brown wire and red/white wire coming out!
CJ Dubs
Oh I see...you mean the plug that connects to the fan motor?? ???
At present I have three wires (as above) coming out of the rad switch - the red/black is cut and goes nowhere, the red/white goes to the rad fan motor and the red/brown goes back into the loom somewhere.
So you're saying that the rad fan motor should also have three wires (because it currently only has two) - the red/white which goes back to the rad switch, a red/brown (I think) which goes back into the loom and this red/black which also goes back to the rad switch?
I haven't got the loom with me to check but I'm guessing that if I look at the fan motor plug then this should have space for 3 wires then!? ???
Cheers,
Chris.
physicsfool
Hi,
Yeah, my (red/black) loops into the fan motor plug. So that it has 3 wires
Martin
CJ Dubs
Cheers geezer - I shall look tonight! ;D
physicsfool
Are you replacing the whole loom or just sections with new wires?
CJ Dubs
Whole loom!
Well...long story short I'm actually putting a G40 in a MK1 so I'm not so much replacing like-for-like but replacing altogether i.e. I took the MK1 loom out a few years ago and only now just getting round to checking the G40 loom (which was working when I drove the crash damaged G40 home a few years ago now) and putting that (complete) in the MK1 shell.
Cheers,
Chris.
physicsfool
#7
I priced up a whole new loom and i reckon its going to cost about 150.
Have you found a decent crimp terminal supplier?
CJ Dubs
So far I haven't needed to change or add anything to the loom - this broken wire has been my only issue so I haven't needed to buy any supplies.  I literally unclipped it from the G40 donor vehicle and clipped it in place in my MK1.
physicsfool
Ah, fair does, i am replacing the whole lot to hopefully improve signal transfer. plus the looms are 20 years old and the copper is becoming brittle.
