G40 running gear and managment components for sale
Started by MaxGT, March 18, 2014, 03:18:27 PM
MaxGT
Hey,
Have these for sale, no longer needed and taking up room. Located in Sheffield, will post for extra, please ask.
G40 ECU, standard chip I believe, will have to check - £100
Inlet manifold - £30
G40 throttle body with BRV unit removed as I'm keeping it - £60
Will listen to offers on it all, prices are what I've pulled off other for sale ads so believe they should be accurately valued.
Have basically stripped down a G40 engine, keeping the block, gearbox, head, charger, charger mount and BRV, so if there is anything your needing that is not on the list above, please let me know and ill see if I have it.
tadpole1987
hi mate in interested in the fuel rail and injectors and i dont surpose you have the standard boost pipes from intercooler then it runs under the front pannel then joins to the pipe that goes to the throttle body and i also need the boost return pipes from throttle to cylinder head and then to the charger if you have any of these and wanna get rid of them ill have them off you mate
samuel.cole
tempted with the distributor if you could send me a few pics?
MaxGT
Bergcaddy
I'll have the loom. Can collect only in Wakefield.
goldfax
If you still have the ECU, I will take it. HOw much to post to Dublin, Ireland
Alexis
