Author Topic: Headlights playing up...?  (Read 2621 times)
Offline Richvw18
« on: March 10, 2014, 04:42:55 pm »
Hi all....not sure if anyone else has had the same probley as me but hear it is...
I put an after market hid kit on...hi and low beam and worked fine apart from i noticed when switching the
Side lights on..the hids came on two...
So ive taken them out and put a good set of standard bulbs back in
But still when i put the side lights on its putting my diped beam on just a little....?
This is my second switch aswell as i thought it was that...
Any help anyone please....
Offline sleag40
  • Poloist
Re: Headlights playing up...?
« Reply #1 on: March 10, 2014, 09:11:35 pm »
Disconnect the cylindrical resistor type device thats bolted to the inner wing next to the fuse box under the screen passenger side.
Offline Richvw18
« Reply #2 on: March 11, 2014, 11:22:17 am »
Thanks for that..ill try it later...does this mean i need a new one....?
« Reply #3 on: March 13, 2014, 09:34:58 am »
no, the lights are supposed to do that.  You can just disconnect the dim-dip resistor and they'll not do it any more.
http://en.wikipedia.org/wiki/Daytime_running_lamp
look at the "UK" section on dim-dip regulations in the late 80s - early 90s.
