Wanted - BRV pipework to rocker cover
Started by Purple Tom, February 24, 2014, 12:25:01 AM
Purple Tom
Hi,
I'm after the BRV pipework, the piece that goes from the BRV to the rear side of the rocker cover and incorporates the feed from the breather pipe as well.  Does anyone have one?
Tom
Purple Tom
Bump - can anyone help me with this?  To avoid confusion, it's this one that I'm after, I imagine there's loads kicking around following boost return deletes?
Tom
physicsfool
Due to the rubber deterioration there are very few around, I am in the process of using the original BRV and replacing the most damaged sections with new pipe.
grungeisdead
I've got one, just waiting to see if Olly takes it with the bits he's grabbing off me. I assume he will be running the BRV mod, so should have this spare.
Will drop you a line, when I know for sure
Purple Tom
That'd be brilliant, thanks. I'll wait to hear from you.
Tom
AlfIE40
hi guys, I don't mean to intrude but i am also looking for the same piece of pipe work if anyone can help. muchas gracias
