Any interest in a group buy on Bosch W5 DP0 plugs
Started by randombadger69, February 19, 2014, 12:35:53 PM
randombadger69
As in the title. These can be sourced in packs of 10. Which is not much use unless buying 20. So anyone interested? Would work out around £12 a plug.
Ben.lopo
I got mine from Gsf no problem id give them a try
z3i
Ngk equivalent are just as good and half the price
JoeH
At £6 or £7 I might, but £12 each means £48 for plugs when NGK's are half that...
randombadger69
What youse using?
NGK BPR7 EVX?
Has been superseded with an iridium plug with a resistor? Built in.
Are the number up BPR8's suitable for a standard G?
randombadger69
Thought I'd found a cheap source for these. . Knew it was too good to be true.
KMS on ebay list them as W5DP0 but sent me W5DTC instead at £5 a plug. Chore.
So I'm still considering buying 20 off to get a good price.
Just need three people who want a set of 4.
Tav
randombadger69
How much Tav?
I ended up buying 8 for the price of 10 off Kms. Not impressed. Next time I'll consider stocking some. For now though as there was little interest I'm out of organising a group buy.
Tav
Prob. around the £12 ea. mark I'd have thought.  £48 sounds about right.  The Clio takes platinum plugs too so it was an expensive month.
Save yourself some cash and use the NGK equivalent  :)
