Just to be sure
Started by Robin, December 14, 2008, 02:20:42 PM
Robin
Does the chip sit in this orientation or the opposite way with the grey line nearer the edge of the ECU?
well i think they only work one way round anyway
juan
you see on the chip there is a little u shaped indentation on one end that should line up with a small u shaped indentation on the chip holder (this is the general rule in electronics).
although im not sure when it comes to g40 ecu's, can't do any harm to check though :)
Nick_S
Think the notch goes towards the edge iirc.
Robin
thanks for the input guys
i changed the chip today for a more 'tweaked' one and now the fuel pump won't prime, changed the chip back to the original one and still doesn't work, tried the chip sat in both ways but didn't work so i am guessing i may have killed the ECU.
oh cock.
hmm dknight once had a fuel pump that would only prime when you bridged the relay... was a simple transistor...
Robin
transistor in the ECU pete?
yeah, someone else had suffered it - it was pence, bet he can't remember which one it was tho!!!!
tried other relays mate?
Robin
yeah i tried another relay but Yoof said the relay might not be a working one, the next plan of action is to take the ECU to Yoof's and try it on his Polo and see if it works or not, if not then a G40 ECU will be on the xmas pressie list!
may be repairable you know! but yeah rule ecu out first.
If it's dead Robin give it to Yoof and I'll have a look at it. If it's just the fuel pump drive transistor it's easily fixed.
Robin
cheers Andy that would be brilliant!
Robin
Found the problem, looks like i have killed the ECU chips, put in another chip which i got for aquamist set up and the car starts fine and runs fine.
