Few new bits
Started by OCDmatt, January 29, 2014, 01:47:29 PM
OCDmatt
Just sorted a few new bits to the site
Main ones with interest to you guys will be the rebuild sets
Head set - http://www.onlychargeddubs.co.uk/products/cylinder-head-gasket-set-g40.html
Bottom end set - http://www.onlychargeddubs.co.uk/products/bottom-end-gasket-set-g40.html
Head bolts - http://www.onlychargeddubs.co.uk/products/cylinder-head-bolts-g60-g40.html
All from Elring so top quality, they're not commonly ordered so may take a couple of days to get in stock as my engineers had a bit of hassle getting the bottom end set.
Cheers Matt
Cool - the bottom end ones are hard to come by.
Just for info Matt,  vw use different head bolts for g40 and g60s.  They g40s are higher tensile 12.9 - normal are 8.8 as per cl/gt ones and are 2mm longer. So I'd assume that these are the 8.8 ones. (as vw charge £7-8quid a bolt for g40 spec ones)
OCDmatt
Yeah, supplier said it was! We should be able to keep getting them, just making folk aware it might be a few days at least :)
Ah, ok, I know they've different part numbers but they've come boxed up for VW engines, 1.0-2.0. It doesn't say 8v or 16v but 16v are a lot longer.
They were ordered for a G40 from a G40 reg & engine code so these are G40 bolts. I'll do some checking to make sure they fit a G60 too :)
OCDmatt
Just to add on to the gasket sets I'm know keeping bearing sets too....only thing I'm struggling on at the minute is con rod bearings but we're looking in to it.
Normally keep standard sizes but if you need oversize then just give me a shout :)
http://www.onlychargeddubs.co.uk/engine-parts/
Quote from: OCDmatt on January 29, 2014, 05:47:47 PM
Elring 819.817 are standard Polo ones. They don't do a proper G40 headbolt alternative that I'm aware of.
gaz g40
I had to get g40 specific ones from VW as nowhere else did them
z3i
Same, and the price for them was insane!!
physicsfool
OCDmatt
Elring seemed happy they'd do the job but I'm doing a double check on it!
Might have to see what I can do about getting them Genuine instead if they come back with something different.
Another thing to add, proper Kluber grease now available in little 15 gram pots - http://www.onlychargeddubs.co.uk/products/kluber-grease-15g.html
OCDmatt
Yep, they've changed their minds now. Will change the listing as they are G60 only.....
But.....I can get Polo G40 specific matched to part number so will be getting some in stock ASAP :)
Will be £15 plus the postage 8)
