Author Topic: Loom wire quality  (Read 3409 times)
Offline physicsfool
Loom wire quality
« on: January 22, 2014, 09:46:37 am »
Is the engine loom made up of generic copper centred wire? Or is it of a higher spec?
Re: Loom wire quality
« Reply #1 on: January 22, 2014, 09:54:40 am »
it'll have higher-temp insulation but nothing out of the ordinary.  Multi-strand copper wire.  Somewhere like vehicle wiring products will have wire specifically for engine looms.
Offline physicsfool
« Reply #2 on: January 22, 2014, 11:34:03 am »
Cheers, does anyone know what the current carrying capacity of the wire needs to be?
« Last Edit: January 22, 2014, 02:16:13 pm by physicsfool »
Offline physicsfool
« Reply #3 on: January 22, 2014, 03:05:18 pm »
Highest rated fuse is 20A so that answers my question
Offline Andy
« Reply #4 on: January 22, 2014, 07:50:10 pm »
20A fuse will need to have well over 20A pulled through it to blow, so you should size the conductor with some headroom over this figure to ensure the wire is capable of carrying the fuse blow current. If you don't, your fuse might sit happily at 25A during a short-circuit, and the wire gets hot and ends up acting as the fuse instead.
Offline physicsfool
« Reply #5 on: January 22, 2014, 09:17:39 pm »
Yeah looking at the thinwall cable rated at 33A
Offline quiksilver_jake
« Reply #6 on: January 28, 2014, 02:19:35 pm »
Thin wall automotive wire is what you'd want, I've found some tri rated in my original internal looms.
You want copper multistrand cores, size wise depends where on the car and for what as the seem to range from 0.33mm (7/0.2 strands) 24 AWG to 2.5mm (35/0.3 strands) 13 AWG. Best looking what was there before if that is possible...
This is one supplier we use at work http://www.autotechnik.co.uk/Products/Automotive-Cable
« Last Edit: January 28, 2014, 02:25:33 pm by quiksilver_jake »
