Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Technical
Engine and Transmission
Oil Pressure switch locations
« previous
next »
Pages: [
1
Go Down
Author
Topic: Oil Pressure switch locations (Read 2036 times)
on:
December 31, 2013, 01:23:57 pm »
Im playing around with my oil temp sensor for the gauge, im moving from the sump to the head, not a fan of it being so low and temps rarely get above 50 degrees on normal driving. Without buying more adapters etc can i get away with this?
Or do they have to be in these locations?
Traders
I know naathing..
Re: Oil Pressure switch locations
Reply #1 on:
December 31, 2013, 05:24:20 pm »
Depends what you want to measure, sump temp will be hotter than gallery (the head) but to get a good temperature reading you need flow over the sensor, which is why most people use a t-piece off the charger feed, or stick it in the sump.
Reply #2 on:
December 31, 2013, 06:06:33 pm »
I thought head temps would be higher than sump. On a cold morning like leaving to go santa pod it took about 25 mins for the oil to get to 40 degrees.
I cant use a t-piece on the charger as im running a standalone again.
I was looking at getting a standard sandwich plate, oil thermostat and a temp gauge adaptor. Will have flow going over it but its expensive.
Can i run them oil switch's from one hole like the 1st picture?
Reply #3 on:
January 01, 2014, 04:00:57 pm »
Just found this and its been set up like mine so guess it must be ok to run.
http://www.vagcat.com/epc/cat/vw/PO/1992/120/57/1257657/
Pages: [
1
Go Up
« previous
next »
Technical
