Author Topic: PSD air/fuel ratio gauge difficult to see in the day time  (Read 3711 times)
Offline DaBigGinger
« on: November 22, 2013, 02:38:00 pm »
I have a PSD air/fuel ratio gauge, but it's almost impossible to read it in the day time as it's too dim. At night time it's fine, though. At the back, there looks like a hole for a light bulb, so I was going to pop one in and see if that helps things out a bit. Does anyone have one of these and do you know what type of bulb/fitting is required to fit the hole. Also, if any of you use one of these, did this sort the brightness issues?
Thanks!
Re: PSD air/fuel ratio gauge difficult to see in the day time
« Reply #1 on: November 22, 2013, 02:44:12 pm »
do you have a picture of it?  I guess you could use any bulb that is 12v and physically fits.
Offline DaBigGinger
« Reply #2 on: November 22, 2013, 05:18:05 pm »
Hey Paul, I just tried to remove the gauge, but it's stuck in the pod pretty well. I can see the hole for the bulb - it's a circle about 4 or 5mm. I was wondering if there's a particular bulb type to fit in that space :)
« Reply #3 on: November 25, 2013, 09:16:43 am »
does the gauge not have a manufacturer's name on it or anything?
Offline DaBigGinger
« Reply #4 on: November 27, 2013, 11:22:29 pm »
It definitely doesn't have one on the front. I'm not sure where PSD sourced them from either. I might have to apply some brute force and remove it from the pod and have a play around with some fittings and see what does the trick.
« Reply #5 on: November 28, 2013, 11:19:31 am »
Offline DaBigGinger
« Reply #6 on: November 28, 2013, 11:59:45 pm »
Sure, I can get one on Sunday :)
Offline DaBigGinger
« Reply #7 on: December 01, 2013, 09:28:41 pm »
Here it is:
« Reply #8 on: December 02, 2013, 09:24:10 am »
oh right, an electronic one.  I'd be surprised if there was a way of backlighting it.  You'll need to remove the actual gauge from the pod and see what you can see.  Perhaps there'll be a pot to adjust the LED brightness?
Offline DaBigGinger
« Reply #9 on: December 02, 2013, 05:59:40 pm »
No, there's nothing like that :( I've seen some mechanical gauges on the Demon Tweeks site, so I might give one of those a shot :) Thanks anyway!
