oil breather..excess oil?
Started by metz, November 16, 2013, 04:10:43 PM
metz
Ive noticed a bit more oil than normal in the pipes that attaches either side of the cam cover. as if its coming from the oil breather thats attached. ive checked the rest of the pipework and theres oil in there but its more a film rather than a drip. I was thinking of getting the blanking plate and a catch tank to eliminate the excess oil getting sucked up but been advised ptfe is no good by OCD matt. so unsure of which way to turn at the mo. either way is the oil normal with the extra bit of boost. 13psi rising to a tad under the 15psi at 6k. 65mm pulley, gt inlet and a map from pete and andy.
samg40
Nothing wrong with using ptfe as long as you use the correct stuff and in the correct amounts. I've run chargers like that for years with no issues at all.
metz
i may have to come visit you to find the correct amount setting on my finger...ham fisted!
the dirty oil going through the charger cant be that great
