Author Topic: Digifant I information  (Read 2488 times)
Offline Alexiskayak_7
« on: August 28, 2013, 03:12:12 pm »
Hello huys,
I know that there is a lot of information here, in articles section, but i need more.
I am writing my final paper for my university and i need information about the digifant system that g40/g60 uses (mostly G40).
Any technical information/files/pdf, about digi 1 ecu, sensors and other components that i may forget, is very useful.
Thank you very much, Alex
Offline z3i
Re: Digifant I information
« Reply #1 on: August 28, 2013, 03:18:36 pm »
I think the g40 is digifant 2 along with the later mk2 golf gti's
« Reply #2 on: August 28, 2013, 03:52:14 pm »
No, its 1. It's stamped in the sticker of the ecu
« Reply #3 on: August 28, 2013, 05:28:07 pm »
I saved these once that someone posted on here.  Not sure if they're any help to you or not.  They are some datasheets for the Motorola M68HC11 8-bit CPU chip:
http://derby.polog40.co.uk/g40ecu_cpu_datasheet.pdf
and the MC68HC25 add-on IO chip:
http://derby.polog40.co.uk/g40_io_chip_datasheet.pdf
« Reply #4 on: August 29, 2013, 12:04:28 am »
Thank you hayesey.
There is a bit of info that i can write from the files that you sent me.
