Author Topic: PPP Chip and Cams  (Read 9726 times)
Offline physicsfool
Re: PPP Chip and Cams
« Reply #15 on: October 04, 2013, 09:09:33 am »
All looked/turned ok
« Reply #16 on: October 04, 2013, 12:40:05 pm »
Cam bearing caps clean and in the correct order?
Offline physicsfool
« Reply #17 on: October 04, 2013, 01:36:07 pm »
yeah and tightened to 6nm followed by a 90* turn. covered the followers and tappets in special grease
Offline physicsfool
« Reply #18 on: October 04, 2013, 07:13:18 pm »
So I resolved the issue... Popped the original chip back in and she roared into life
Not quite sure how the chip became damaged but you can see a burn mark on the centre if it
Offline Andy
« Reply #19 on: October 05, 2013, 12:29:35 pm »
Looks like you've popped it in the wrong way round, usually damages part of the memory which is why it won't be running properly. I can do you a cheap replacement, but am away at the moment - drop us an email.
Offline physicsfool
« Reply #20 on: October 05, 2013, 02:33:56 pm »
Ah smashing, thanks for that!
Offline physicsfool
« Reply #21 on: October 27, 2013, 05:32:32 pm »
Thanks to Andy I now have a fresh PPP chip in. Before i swapped cams and chips over car idle was a tad high 1200rpm but nothing ridiculous.
Since swapping everything over the idle has become rough/high when the car gets warm. When i turn it on, its at about 1100 rpm but once the car gets warm it rises to 1800rpm once i apply the clutch. The idle will sometimes drop if i apply the clutch and 1st gear a touch. but mostly it rises back to 1800.
i spent the day going over the diagnostic guide on here, only thing that confuses me is the co pot reading, when i put the multimeter to points 1 and 3 the cars rev drop right down (like its about to stall) and reads a really small resistance.
when i remove the blue temp sensor at running temp the revs rise, however i realise i didnt set the ignition timing when it was in service mode, will this make much of a difference?
and my cam timing is still half a tooth out.
Offline Andy
« Reply #22 on: October 27, 2013, 08:01:10 pm »
It's essential to set ignition timing in service mode. Do that, and set the CO pot resistance to circa 550ohms as a starting point.
Offline physicsfool
« Reply #23 on: October 27, 2013, 08:42:24 pm »
How do i adjust the CO pot resistance?
Offline Etches
  • Still got the G...
« Reply #24 on: October 27, 2013, 09:32:39 pm »
Measure across pins 1 and 3 after you take the loom clip off, I set mine to 550ohms before it went on a mates exhaust gas analyser. Think he riched it up after changing the blue temp, melted fuel pump relay and lambda
Offline physicsfool
« Reply #25 on: October 27, 2013, 10:42:53 pm »
Cheers for that lad, I will set up the timing and resistance and holla back
Offline physicsfool
« Reply #26 on: October 28, 2013, 11:50:07 pm »
So I timed it up in service mode. Sounds much better.
When I checked the resistance in the CO pot it was 850, dropped that to 550, although doesn't feel like it's idling quite as smoothly. Should I try increasing to 600/650?
« Reply #27 on: October 29, 2013, 08:14:31 am »
What's your idle speed? Idle switch engaged?
Offline physicsfool
« Reply #28 on: October 29, 2013, 08:45:17 am »
Before I adjusted the CO pot it was 1000rpm. Now it's up to about 1100rpm.
« Reply #29 on: October 29, 2013, 09:38:13 am »
Too high - adjust it down, is the idle switch engaging too?
