Flywheel bolts, torque settings?
Started by sparkz786, July 24, 2013, 12:12:15 AM
sparkz786
anyone got the flywheel bolt torque settings to hand? tried searching around to no luck :/ cheers guys :) and ps does the clutch plate need to be torqued aswell?? if so what figures aswell? lol
sparkz786
#1
got the flywheel settings i hope, 25nm?
but need the clutch plate torque settings if possible?
Robin
These are listed in the Haynes manual.
25nm is no where near, they are 60nm plus 90 degree. The clutch cover torque is 20nm for 5 speed, 25nm for 4 speed. Will post it up as well.
From Haynes
Torque wrench settings        Nm      Ibf ft
Cylinder head bolts (engine cold):
Stage1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 40      30
Stage2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 60      44
Stage 3 (angle tighten) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . + one half-turn (180"), OR + two quarter-turns (2x90°)
Main bearing cap bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 65       48
Camshaft cover screws . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10       7
Camshaft sprocket bolt . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80      59
Inlet manifold nuts/bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25    18
Exhaust manifold nuts/bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25      18
Flywheel bolts:
Stage1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 60     44
Stage 2 (angle tighten) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . + 90°
Sump . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20    15
Oil drain plug . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30  22
Oil pressure switch . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25    18
Crankshaft sprocket bolt . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80     59
Crankshaft oil seal housing bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10       7
Auxiliary drivebelt pulley bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20    15
Oil pump mounting bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20    15
Oil pump cover bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10    7
Oil pickup tube screws . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10    7
Clutch Torque settings:
From Haynes
Pressure plate to flywheel bolts:
4 speed transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .25   18
5 speed transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .20   15
sparkz786
