Polo hall sender 6n2 fit g40?
Started by z3i, April 15, 2013, 09:30:58 PM
z3i
I remember reading somewhere that the, pretty sure it was 6n or 6n2 1.4 16v hall sender fits the g40? has anyone got a part number? is everything the same? all the seals etc?
would rather get a bosch one
Taylor
theres a thread on this on club polo in engine faq ill find it a link it here later
a 6n one from a multi-point 6n will work.  I'm not 100% sure the hall sender will fit in the g40 dizzy (although I think it will).  I use the whole 6n dizzy on mine.
z3i
Quote from: hayesey on April 16, 2013, 09:13:18 AM
ah ok, thats even better!. Would make more sense to go to the scrappy and get a complete unit then :)
thanks mate
the only difference is that the hall sender connector will now be at the back of the dizzy but the normal wiring still reaches.  It's just a case of putting it on and timing it up as normal.
z3i
Since fitting this, the car has been really jerky (not the beef kind) if i accelerate lightly at a low speed and low rpm it kangaroos like mad!
and i was giving it some on the M way in forth at 5k rpm there was no power it just had a flat spot, so changed up a gear and put my foot flat and it started misfiring! im really concerned ive damaged something
any ideas? the dizzy i got is from a low mileage car, but could it be duff? whats the symptoms of sendors on thier way out?
many thanks Taylor
yeah have you timed the new dizzy up?
z3i
Sorry, didnt come up as replied too
yeah all timed up correctly
when its running again i will change back to the original and see if it makes a difference, go from there. Would incorrect timing cause these symptoms?
it would yes, assuming the dizzy you've got is OK.  I don't have such problems on mine, it works fine with a dizzy from an AEX engine code 6n.  What engine is yours from?
z3i
I dont know, didnt think to get the engine code, i will get the vernier calipers out and measure the trigger wheel gaps
See if its the same as the g40
will double check the timing when its back together, was in a rush when i last did it, but im sure it was spot on
thanks Taylor
z3i
Morning, sorry this was my fault, checked the timing and it was too far advance, must have missed something accidently when i was in a rush setting it up. All spot on now
thanks for your help
