removing supercharger
Started by vikash, June 20, 2009, 12:25:49 PM
vikash
Need a little help.
My head gasket has gone so thought I would start working on it. I am stuck already on the Supercharger.
The charger is free but there is no space to remove it. I have removed the intercooler but there is still not enough space!
looking at the faq it says to remove the pulley then remove the 13 bolts for the bracket.. now i can not see the bolts and do i have to remove the pulley?
Thank you
Robin
you can take it out by jiggling it around.
Alexiskayak_7
Or unbolt the engine mount bolt and lift a little the engine...
vikash
I tried jiggling as much as I could.  :(
I will try again on Monday, hopefully it will come out and I can start the actual work.
Nick_S
Yep you need to remove the charger pulley if you want to take it out through the top of the engine bay. Even then you have to twist it something like 90 degrees to get it past the slam panel without scratching it.
SuperMario
i got mine out without removeing the pully, just turn it around ware ever possable will it squeezes its way out.
and i done my headgasket leaving the charger in :S
vikash
musto you did the headgasket with the charger left in?
did the exhaust manifold not get in the way?
SuperMario
The exhast manifold came off with the head! The studs were beyond cleaning up so just undone it from the other end of the manifold, a 19mm i belive (dont hold me to that)
