Timing mark?
Started by busy t, May 06, 2009, 07:08:09 PM
busy t
Just a quick question regarding timing, is there a timing mark on the plastic cambelt cover? If so where would be the best/cheapest place to get a new one? My mechanic seems to think that when my toothed belt has snapped it has eaten into the cover and erased the mark.
Thanks, tom
Dan
It is a metal pointer as standard on a G40. The mark is a groove in the pulley. You should be able to buy it from VW.
on later ones (replacement bottom vw covers) its a marker on the cover - a jutting out bit of plastic
