Digifant I information
Started by Alexiskayak_7, August 28, 2013, 03:12:12 PM
Alexiskayak_7
Hello huys,
I know that there is a lot of information here, in articles section, but i need more.
I am writing my final paper for my university and i need information about the digifant system that g40/g60 uses (mostly G40).
Any technical information/files/pdf, about digi 1 ecu, sensors and other components that i may forget, is very useful.
Thank you very much, Alex
z3i
I think the g40 is digifant 2 along with the later mk2 golf gti's
Alexiskayak_7
No, its 1. It's stamped in the sticker of the ecu
I saved these once that someone posted on here.  Not sure if they're any help to you or not.  They are some datasheets for the Motorola M68HC11 8-bit CPU chip:
http://derby.polog40.co.uk/g40ecu_cpu_datasheet.pdf
and the MC68HC25 add-on IO chip:
http://derby.polog40.co.uk/g40_io_chip_datasheet.pdf
Alexiskayak_7
Quote from: hayesey on August 28, 2013, 05:28:07 PM
Thank you hayesey.
There is a bit of info that i can write from the files that you sent me.
