65mm pulley
Started by AdzCM, January 30, 2013, 12:15:36 AM
AdzCM
I am selling this due to my turbo build.
Full blend PSD charger [maximum ported] with all the banjo bolts [for oil feed/return] and other necessary bolts for the dome, mounting plate and pulley etc.
NOTE: Charger has only done 1500miles since last rebuild so its basically like new. Been lubricated properly with correct PTFE spray.
Inlet collar/blanking plate/large filter/intake pipe and 65mm pulley. Belts will be sent along with pulley although a fresh set would be advised.
£350 inc. postage for the charger.
£25 for the pulley
£15 for the intake pipe + filter
£10 for the inlet collar
Would you sell inlet pipe and filter separate?
AdzCM
Bump
Charger is seriously cheap at that?
Want it gone...
AdzCM
Charger is SOLD :)
Still for sale:
- 65mm Pulley
- Air Filter and Pipe
- Inlet collar
I pm'd about collar, inlet and filter.
AdzCM
Inlet collar, air filter and pipe sold.
65mm pulley left...£20 posted
krazy*k
is the pulley in good nick ?
