Small guide to fit GT inlet manifold?
Started by xrrich, May 01, 2010, 11:55:28 AM
xrrich
Would be appriciated, Do i need a new gasket?
Rich
Its best to replace the gasket. Its probably something that wont get done alot and there not expensive from VW.
hardchargin40
battery disconnect.
Remove boost pipe, and TB.
Unclip wiring connectors for knock, lambda and err other one or remove bracket totally.
May have a strut on the back of the G40 manifold, remove this from under the car.  loosen and remove the ISV pipes underneath and vacuum pipes.
Remove the inlet manifold bolts and stud nuts, withdraw manifold (may need to remove the oil pressure banjos on head if in way, (i forget if there are in way)).
Fitting is reverse of removal.
*Subject to misinformation* - It has been 4years since i did one.
samg40
If your changing the inlet gasket your best off changing the throttle body gasket too. Thats the one thats always pretty manky in my experience.
ereeiz
You should always change gaskets, especially Metal ones, they're the source of many air leaks, air leaks = wrong information being fed to the engine and all sorts of problems such as hesitation, lumpy idle, etc. and for the sake of a few £ you don't have any excuse really :P
Don't use gasket paste on it, that can get sucked in if not set properly and cause a lot of grief.
xrrich
SO .. finally come to fit the manifold, after fixing other problems, What gaskets do i need to buy.
Throttle body gasket and
inlet manifold gasket
Would anyone be so kind to have part numbers :)
jez1272gt
you might want to think about swapping over the fuel rail and injectors as well  :D
When re-seating the injectors in the new manifold lubricate the rubber 'o' sealing ring with a touch of oil. It will stop them from splitting!
