Worth getting a adjustable fuel regulator
Started by John-125, December 18, 2014, 08:41:01 PM
John-125
Rebuilding my G with a g60 charger
With 315cc injectors and uptated fuel pump think it's worth getting one ?
Alexiskayak_7
#1
If you are not running more than 230ps its worthless.
All you need is to properly map the car (if you haven't)
marky-x5
Can I ask what you are doing regarding MAP? I've got to the stage where I'm almost finished with the mods and was hoping to find something off the shelf for now. Unfortunately this hasn't happened and looking to get a custom setup.
Should add that I've also g60'd my G
Mark.
John-125
Hello m8 yeah I'm in the same boat :/ what spec is your engine cam and injectors ?
marky-x5
I've gone for the 276 schrick cam and a set of volvo 315cc injectors. The head is off at the minute and I'm in the process of lightly porting and matching it.
