Bar-tek Coolant hoses.
Started by Bushpig, January 05, 2016, 07:33:34 PM
Bushpig
Anybody used them are they any good for the money? have been told there are 11 pipes in total by bar - tek , one for one swap apparently.
Is there 11 pipes in total from standard?
Cheers.
could always buy them from SFS and its cheaper.
Bushpig
Received a email today , they do 7 piece kit from the pics seems like it is all the majorly pipes that are covered however what would be the extra 4 pipes be for that bar tek supply?
I always wondered that as well.
As far as i can remember there is only 7:
1 x to heater matrix
1 x from heater matrix
1 x from expansion tank bottom
1 x from expansion tank top
1 x U bend shape from housing to water pump pipe
1 x to radiator
1 x from radiator
Where the other 4 pipes are, i have no idea where they get that from.
Bushpig
Even if you included boost system still doesn't add up....
quiksilver_jake
Better to sort it out with SFS and then we call all easily access SFS within the UK.
Dan, Pm'd too.
The coolant set would be good to sort out with SFS with the extra Jezza says.
Boost pipe wise I'm on BRM like most so it would only be 3 straights 57mm ID and a bend for the glader to intercooler to replace the hump hose.
If you are looking for a full set of replacements as standard you will want to sent a set to SFS I think.
