Running gear from my G40
Started by samg40, June 09, 2015, 01:23:02 PM
samg40
Hi there, as the title I have a list of parts I am selling. Quite willing to do deals if buying a lot of stuff. Postage is available on the smaller stuff, otherwise collection is from Sheffield although I am travelling about a bit over the next few weeks/months so get in touch if there is something you want and are miles away.
I will take pictures of things if needed.
Engine, it had the head rebuilt about 20k ago after a head gasket failure. Does not smoke and feels very strong, has always made good power. New cambelt and waterpump 2k ago in May of 2013.  £300 SOLD
Gearbox with Quaife LSD, covered around 1200 miles since fitting. Fitted at Stephen Brears gearboxes in Leeds, gearbox was stripped and new second gear synchro fitted. £850 SOLD
Standard ATV G40 gearbox. £300 SOLD
Lightened flywheel as Pete was doing. £70 SOLD
Helix paddle clutch. I was using this with a standard pressure plate (which I can chuck in) and it was fine. Covered 2k miles. £100 SOLD
Ported GT inlet £40 SOLD
FK Konigsport coilovers. £350 SOLD
256mm Audi brakes with discs/pads. £200 SOLD
Vernier pulley. £100 SOLD
Braided brake hoses. £20
In line fuel pump. £35
In tank fuel pump. £15 SOLD
Alu Direnza radiator and slimline fan. Also comes with adaptor for the temp sender as they are a funny size for some reason. £150 SOLD
PPP exhaust, cat back system. Slight graze from a rubber failing incident. £300 SOLD
Engine loom, only issue with this is the plug has been cut off for a slimline fan. £80
Steering damper. £35
Starter motor. £20
Dewedged throttle body. £50
Standard exhaust manifold. £20
G40 engine mount/charger bracket. £20 SOLD
Varta battery. £15
Bosch silver battery £15
14" OZ F1 wheels with Yoko A539's. £350
14" Compo MO £350
Khumo V700 track rubber powercoated in white. £100
Late spec rear lights with euro fog light. £40 SOLD
Set of headlights with clear side repeaters. £40
VW Front rubber floor mats. £20 SOLD
Dizzy with cap and HT leads £60
PSD catch tank with hoses to go to breather. One of the take offs has broken off. £10. SOLD
MartinB
PM'd regarding braided brake lines.
Etches
samg40
#3
Post updated and some photos added.
Etches
Crap, I needed some clear indicators! See you next weekend Mr salesman.
samg40
I've got another set in the garage as well as these. You can have em fella.
sleag40
Do you still have the front mats chief?
samg40
sleag40
tadpole1987
hi mate can i have the fuel pump please
samg40
Yep no problem. Pickup or posted? Drop me a pm.
samg40
Updated with what I've got left. I've got some more random bits to add too.
westy02
G40wiring loom is there one still for sale
samg40
Quote from: westy02 on October 26, 2015, 08:18:58 PM
Yes I still have the wiring loom.
