Bar - Tek or Jabba
Started by Bushpig, September 23, 2014, 10:58:58 PM
Bushpig
Evening all .
Have been pricing parts up for my g40 that is standard as they come , all im wanting to do to not spoil the original look is work to the charger and possibly cam and ignition leads,
Now since PSD packed up , been looking at two different routes
1. Jabbasport 65mm pulley with belts and chip and also extra wide timing belt and stage 4.
2. Bar-Tek toothed pulley kit +toothed belt , chip , wide timing belt stage 4 charger from Jabba.
Has anybody had any experience with bar-tek?
Cheers in advance.
For charger porting its hard to beat JNL
dekerf1996
From what i have seen JNL look great for charger porting, and is where my normal chargers are going
Careful on the toothies though as a lot are steel and therefore heavy. Look out for some second hand PSD toothies instead, much better as they are alloy
I run steel ones now, i find them no different at all. Once there spinning, there spinning. Plus they dont wear bad like some psd ones.
