eaton toothed pully set up?
Started by poloeatonm45, December 10, 2008, 08:00:09 PM
poloeatonm45
does anyone know where i might be able to get hold of a 19 percent smaller {than standard} toothed pully to fit my eaton charger ??? i really need one
i got a spare toothed pulley - worn a bit tho.. for eaton. i can measure it if you want
pete
poloeatonm45
yeah please if you could. will if fit the standard charger or is it from a psd modified charger????????
very interested in this
steven
poloeatonm45
poloeatonm45
their must be somewere i can buy a set o toothed pullys for an eaton charger
from what beavis used to say, the eaton pulleys were an interference fit as standard. with a smaller pulley (toothed probably even worse) they could spin on the shaft, hence why he modified the shafts/pulleys to accept a keyway.
poloeatonm45
ah i see i never even thought of that
