Cams
Started by RyanC, August 13, 2013, 09:45:49 PM
RyanC
I've been reading up on aftermarket cam and how they work but still can't really diside on what one to have I think for the spec I have a 252/276 Schrick cam is ideal, if anyone can shed some light that would be sweet!
I've had a look at some other threads but no luck on a overall disistion.
My spec will be
Full blend on Totthed pulleys
Fmic
51mm tb
gt inlet
Bvh
1341 bottom end
Ppp exhaust
Lot more little things but that the main bits
I will obviously run a vernier pulley too!
Cheers peeps
Phil
That Shrick would do well with your spec.
polo classic
Whats your valve size?
Did the head come with flow figures`?
RyanC
Normal size inlet and 31mm exhaust I'm still building it all up so I haven't even run the car yet but I want to make sure I get the right came. I will get my the head flowed anyway
polo classic
if you know flow at different lift, this can help your cam selection
