new 1.3/gt/g40 catless downpipe (free manifold and gasket to go with it)
Started by RyanC, July 09, 2013, 08:32:57 PM
RyanC
i bought it a few weeks ago but know im getting a 4 branch so dont need it, it has a egr outlet which you can weld up if you dont need it (if your running carb) or if you need a lambda hole then u can cut the pipe part of the egr off a weld a nut for a lambda in easy job to do.
will also chuck in a gt manifold (needs some of the downpipe studs drilling out and new studs putting in)
also got a new manifold to downpipe gasket which i will put with it too
the down pipe alone cost me £30
im wanting £20 plus postage or collected from basingstoke rg22
