HELP PLEASE :) GT to G40 confusion
Started by polo-lover!, November 08, 2012, 12:31:02 AM
polo-lover!
Hi guys,
I have a G40 but due to lack of funds i have had to put a GT engine into her untill i can afford a g40 conversion, i seem to have done everything that i know of but she wont start, not even turn over, nothing, is there any modifications i have to make or add to to make this work as i thought it was simply plug and play  ???
please help guys.
Many thanks
Jamie
so there's no sign of life at all?  The starter motor doesn't even spin?  Start with the basics, check that the battery is charged, check the thick wiring between the battery and the starter motor.  check that your engine earth straps are all in place and OK.
polo-lover!
no mate, no sign of life at all, the lights and indicators and wipers work, there isnt the usual humm sound that comes when you turn the key that 1 click if you know what i mean, it completely dead, i have checked what you suggested and had no luck, any chance you know what to do from here??
many thanks
jamie
g40will
That humm is your fuel pump primeing that could be a relay or fuse or dodgy connexion hope this helps, is it turning over and failing to fire or is it not doing any thing at all?
polo-lover!
gaz g40
have you put the connector on the starter in the right place..... little wire where theres two places for it to fit and itl only work on one of them
POLOMON
This is a wiring issue then, given that, have a search for my username.... If there had to be a wiring issue sods law i had it when i fitted my G, It could shed some likght on your issue.
Good luck :-)
you're going to have to start checking the wiring.  The fact the fuel pump doesn't prime could be a sign that either the fuel pump relay or ECU relay isn't working (both are on a clip next to the ECU).  But the starter should still turn, that's just controlled by the ignition switch.  Worth checking the ignition switch actually!
polo-lover!
i shall have a play today and get back to you at the end of it, thanks so much guys! hopefully she will be running later on! :)
Craig g
Looks like were in the exact same situation,
I've just converted my 1.0 to a g40 n went to start it for the first time and all I get is a click now fuel pump priming or anything just a click, been searching through all the posts on the forum trying to find a solution but still nothing :(, if you solve yours let me know :)
Andy
Check the connectors at the back of the fusebox where the interior harness joins the engine bay harnesses.
polo-lover!
Justin14100
polo-lover!
the GT ecu is in there... with the GT ecu loom.. is that correct?
Andy
Did you check the connectors at the front and rear of the fusebox were okay?
