Engine Missing underload
Started by si polo coupe, July 07, 2012, 06:41:50 PM
si polo coupe
Hey guys just blew my coil up and replaced it with another spare i had. Since now and all the lovely weather we've had the car is now missing unload. Have changed dissy cap and rotor arm and ht leads and its still doing it have also adjusted the copot to see if that was it and set it to 600 ohms. I dont no what else to check. Any ideas
scotsjohn
New coil needed; but how did you fry the original?
AlexG40
As above, it's likely to be the things you changed just before it went wrong. But you need to fix the underlying issue first.
si polo coupe
Was just driving put into second then went pop. So you think the coil is braking down still
si polo coupe
is replacement coil new???
if not buy a new one
si polo coupe
No its a spare i had. It only does it underload in third forth and 5th. 1st revs all the way out and second. :(
AlexG40
It's not that easy to put 1st and 2nd under load especially in a G40.
Andy
Buy a new coil, but not a Made in China cheapie.
si polo coupe
Found the problem number 2 piston closest to the dissy the electrode around the tip of the plug had cracked and dissapered and has lost the end of the plug inside onto the piston. Which apperently might of cause the coil to blow. Ive managed to get the end of the plug out from ontop the piston thro the plug hole. Put a spare plug in and took it down the road and all seems good now :)
