g40 charger noise need help
Started by stevie-doh, May 27, 2012, 04:16:22 PM
stevie-doh
how do i go about gettin more noise out of my standard charger
DKnight
few pebbles in the inlet will do it
brownysblower
grayg40
like to the above comments :)
if its still the v-belts tight ten charger belts to correct tension and use belt grip spray grease stuff of get a set of teethed pullies and belt but this reduces service life
stevie-doh
dont really want to do much to the engine as its completly standard and sort of want to keep it original thanks for the help buddy
DKnight
infact losen a few bolts securing it that will cause vibrations and make quite a racket too
stevie-doh
cheers for that very helpful now
scotsjohn
Most folk want a nice quiet charger mate. Get rid of the standard filter and fit a cone filter. Eventually you'll throw away your pointless sound system which you won't  be able to hear and you and your mates will have to learn sign language, but it will make the noise you want.
You'll probably need to get your charger serviced more often as most cone filters aren't as good at filtering the air as the standard paper filter.
stevie-doh
thanks for that mate il give it a try see what its like can always go back to the standard version if i wish. thanks again
Justin14100
the best induction type kit is the jabba sport one as it has a heat shield too
stevie-doh
were would i be able to get one of those from and how much do they cost
stevie-doh
found one of these on jabbasport at £123 which aint bad i thought it would be a good bit more. it says for a jabba r1 would this induction kit fit a standard charger
SuperMario
Quote from: stevie-doh on May 30, 2012, 05:10:57 PM
Yes
