K03 ROTHE manifold outlet diameter
Started by dubstar, March 06, 2012, 12:42:37 PM
dubstar
Hi Guys,
Can anyone tell me what the diameter of the outlet is of the K03 ROTHE manifold please?
Thanks in advance,
Ross.
N1CKY
Ill check tommorow when im in the garage on that exact manifold seen as though you used my picture ;)
dubstar
breadman
Just checked my Rothe manifold - 39.2mm.
dubstar
Robin
Breadman don't suppose you could measurement the distance between the 3 bolts holes could you please? I need to buy a new gasket but need the bolt hole spacing measurements.
breadman
Ok Robin, as you look at the holes in the pic (all c/c)
Left (bottom) to right = 50mm
Right to top = 59mm
Top to left = 55mm.
All holes 14mm dia.
Hope that helps,
Richard.
Robin
