rear brake conversion
Started by RyanC, December 21, 2011, 07:50:31 PM
RyanC
is it easy to convert from drums to discs and what discs and calipers do u use? thanks ryan
use parts from a mk2, 3 or 4 golf.  Mk4 golf aluminium ones are best as the older iron ones are notorious for seizing up all the time.  But mk4 golf ones are more expensive because they are much more sought after.
You need everything including the stub axles.  You will have to make your own handbrake cables though, use motorbike cable solderless nipples and then a cable from a golf.
