270 front disks ?
Started by N1CKY, December 07, 2011, 10:33:53 PM
N1CKY
My car has 270mm disks on the front, Any idea what they are off so i can buy some new ones? The have a adapter plate where the calliper bolts on so bigger disks can be fitted.
Nicky
Raw
Do I not remember a being discussed before that these were a Vauxhaul 280mm disk turned down to 270?
dub-disaster
I thhought they where rover items turned down ?
Yeah turned down rover disc's.
youngprodigys
no there not- there custom discs. there the same height and centre bore as the rover discs but the rover discs in question need to have the bolt pattern changed as they are 4x114 and not 4x100. so TSR must buy them in bulk with the specification changed to include the pcd change.
ive got this setup myself on my shelves and it took bloodynages to find it all out.
im using 280mm honda legend discs (same as rover) with slotted holes to make them 4x100. the main advantage of them is the disc height as it means i could get my 4pot willwoods on without wheel spacers and the brakes fitted loads better.
