Still Won't Start
Started by SteG40, November 07, 2011, 02:24:00 PM
SteG40
Need abit of help with this my car won't start at all won't even turnover, fuel pumps don't prime. When you turn the key you can hear all the relay's working. I have changed the ecu and fuel pump relay and made no difference.
We have put power to the fuel pumps and they work fine.
Tested the hall sender and that's working, we swapped dizzy's too.
Tried a different ecu
Checked all fuses and swapped for known working ones
Removed immobliser
Fitted new battery
Checked the wiring all seems ok because it did run a while ago but then I left it for abit.
Checked all earths
Having done all the above and nothing's solved it, is there anything else I should check. Is there anything that links the starter and the fuel pumps together that could stop them working? Does the igntion coil have any effect on this?
Anybody got any other ideas what it could be?
thanks
SteG40
Solved it reading through other threads managed to figure it out stupid fuse box wiring ;)
N1CKY
on the starter which termanal have you got your starter wire on there is two put it on the one that is on the inside closest to the block i had a simler problem this may help but not 100% sure
