Full left lock
Started by Dan:), September 25, 2011, 03:42:23 PM
Dan:)
When I put the steering on full left lock it clunks. Is it the tyres moving, doubtful of mechanical as I've had that all checked.
Any help will be much appreciated.
dub-disaster
cheys03
Do you have a subframe fitted?
Dan:)
Yes to subframe and Ive checked CV joints.
cheys03
If it's a Stage 3 PPP or a PPS subframe then it's possible you're catching one of the arms from the subframe, probably the offside one. Look at both sides and check for possible binding points.
What are the size and offset of your wheels and tyres?
scotsjohn
Dan:)
original polo steelies and it maybe the top mounts ill have to have a look
cheys03
Could still be the wheels catching the frame, doesn't hurt to check
Dan:)
Thanks  for your suggestions I'm going to have another good look over at everything today. I'll check everything suggested :)
cheys03
Dan:)
Nothing seems to be moving but ive got to change the brake lines at the back so im gonna change them all roung ang take from assembly apart and give a thorough look over :D
