alternator pulley torque setting
Started by Barney, August 16, 2011, 03:31:39 PM
Barney
anyone know how tight to tighten the pulley nut?
cheys03
If you're lucky, the shaft of the alternator will have an allen key hole in the pulley end, enabling you to hold the shaft (oooh errr) while you tighten the pulley. Otherwise either a chain whip on the pulley (I would only do this if the pulley is steel, use an old belt to protect the pulley), an air ratchet/impact gun, or in extreme circumstances a CAREFULLY placed screwdriver in the fan against the case of the alternator while still holding the fan by hand to reduce the load on the screwdriver. Be prepared to bend back the fan blades though if you do this.
cheys03
The above advice will vary depending if the pulley has a woodruff key or not.
cheys03
Looks like he may be after a re-read. 'doh
Yeah me too, well the torque is 20nm if your wondering. Should be able to do that while holding the pulley.
Barney
cheers for that.  The hardest part was getting the alternator back in its bracket.
