Lightening the flywheel
Started by Jake G 4 0, May 20, 2011, 10:59:35 AM
Jake G 4 0
Ok so I have read up on lightening the flywheel and it has it's up's and down's I just wanted to know of any of you lot have done it and weather it's worth doing or weather you wished you hadn't done it etc.
Thanks Jake.
if you want - i can supply £69 exchange
pete
Jake G 4 0
Might be interested pete, what do you think about them??
Jake G 4 0
Also how quickly could I have the lightened one as it is pretty much the last piece I need?
i've not used one!
queue hayesey and yoof to post...
they are exchange - so i have one at momnet, you post yours and i get and send you one thats done back
pete
it's hard for me to comment because it changed so much other stuff on the car at the same time.  But it'll make it rev up quicker. I don't notice any issues with rough running or it being easy to stall.
Jake G 4 0
thanks for the advice lads,
I'm having loads of stuff changed at the same time so probably won't be able to see the difference, but i just wanted to know if you were disappointed with it or....??
Pete can I let you know tomorrow if i want that fly wheel??
Pete- I've got a flywheel for you at the unit, think it's already been skimmed if you want it? Catch me on MSN.
Jake- Even with a few kg taken off them, the car still idles fine, and is smooth, paddle clutch is more of a pain by far!
Jake G 4 0
That's all I wanted to know thanks yoof, although I have heard that you may have some problems with hills??
I have also just ordered a helix road clutch this won't make any difference will it??
Don't have any problems with the lightened flywheel
I run a helix clutch and lightened flywheel and its good. Revs slightly quicker.
I changed both of them together so i noticed a difference. I think its worth it, although torqueing them bolts are a right!!!! pain!!!
Jake G 4 0
sweet cheers guys,
does anyone know the torque rating on the helix clutch??
As in what it can take? I think it is 200nm but im might be getting that confused with the sach one. Does it not say?
My car puts out i think 140 lbf-ft (189nm) and i get no problems.
Oh no, sach is 300nm and i think the helix is 250nm.
Jake G 4 0
I haven't received it yet so i'm not sure.
what sort of bhp are you running?
