G40 parts (updated pictures)
Started by cheddarcheese, March 14, 2011, 03:34:43 PM
Boris
Oops, didn't notice you didn't want pm's till it was too late. Anyway, I'm interested in buying the block. I take it all pistons etc.. are included? is it damaged in any way?
I'm in Scotland, so would you be willing to knock a bit off the price if I were to arrange a courier?
Cheers.
gavin.starr
Im after a loom if you still have yours knocking about.
anythingvw
hi mate do you still have the engine if so how much,many thanks craig
breadman
Still interested in the vernier pulley if you'll split it from the cam?
cheddarcheese
#34
breadman the cam is still connected to the vernier you know of a easy way to remove it from the cam with out damage?
Boris £185 if you arrange courier for a quick sale. no damage was split from a working engine bottom end inc sump and oil pump, pistons the lot!
anythingvw i do still have a full working under 100k engine but will still hold on to this a little longer!
GAF2
Mk1 Berg cup Arches £165
Would these fit a mk3 g40 or are the mk 1's different?  Could you post them to the scottish highlands?
cheers Grant
cheddarcheese
#36
mk1 polo's are different but mk1 arches can be made to fit and look nice. i can post to the highlands but will check price!
GAF2
Yeah mate get me a price posted and i will get back to ya
breadman
Quote from: cheddarcheese on May 12, 2011, 08:42:36 PM
Probably the easiest way is to put an old cam belt around the pulley. Then hold the belt tight in a vice so it strangles the pulley and prevents it from turning. Now with a socket on the centre bolt give the wrench a sharp wack with a mallet - that should free it off.
What make is the vernier and how much you'd want for it posted to SM6? Could you send me a pic or two of it so I can see the condition first though before you start trying to remove it?
Cheers,
Richard.
Boris
Done. Pm sent.  :D
cheddarcheese
arches are £165 +  £15 delivered to the highlands
langersG40
Hi interested in the jabba sport charger what sort of mileage has it covered?
Many thanks
Chris
cheddarcheese
the charger i have no idea what mileage it has done at a guess about 100k but i dont think mileage is a big factor as i have had a charger that was on around 200k and no problems!
cheddarcheese
dub-disaster
