Windsor Blue, non sunroof g40, 109K
Started by dannyb.G40, March 06, 2011, 10:28:28 PM
dannyb.G40
Up for sale we have my windsor blue (best colour), non sunroof G40. She has been my daily driver for the best part of three years, never skipping a beat and I will be sad to see her go, but its time for a change. Any way the details are:
Engine
109,000 miles
Charger rebuilt 15K ago by Jabbasport
Cone filter
GT inlet
65mm Toothed pulleys (+chip to suit)
4-2-1 manifold
Powerflow exhaust
Samco hoses
Drive
60/40 TA Technix shocks and springs
G-laderseite ARB blocks
Staggered Smoor Roadsters 13x7 front, 13x8 back (with a little stretch  8-) )
Interior/Body
Boost Gauge
Debadged Grille
Trim removed
Not massively modified but enough to give it a bit of poke! The car has been well maintained during my ownership with the following having been replaced (I'm sure theres more but this is all I can think of atm):
Battery tray repaired following rust damage (common problem)
Both fuel pumps
Alternator
Hydraulic tappets
fuel tank (painted and undersealed before fitting)
cambelt/waterpump
lambda sensor
blue temp sensor
rear wheel bearing
rear brake cylinders + shoes
regular oil changes every 3000 miles
Bad Bits:
As you can see from the pictures the bodywork is generally quite shabby. There is lacquer peel on the bonnet and roof and the drivers side has a few areas of rust showing which seem to have sprung up this past winter. I was never in a position to fix the bodywork due to work commitments/other areas of the car to spend money on.
The freezing mornings have caused it to idle rough when cold, this could just be a case of replacing the blue temp sender again (they are notoriously bad). After a few minutes the car is fine.
Extras
The car will come will all parts to return it to standard including:
Inlet manifold
Original pulleys
exterior trim (including badged grille)
Airbox
Manifold + Cat
The car has two sets of wheels and I am confident I can get the money back I paid for the smoors therefore will have two prices listed; one with the winters (14" bbs RA's, see below) and one with the smoors + winters. Please note CD player will be different to the one shown in the pics.
With that in mind I'm asking:
£2300 ono with smoors + winters
£1850 ono winters only
Cash sale only, i'm not interested in a p/x thanks.
The car is based in Malmesbury, wiltshire.
Contact me via PM or on 07825669797 after 5:30.
Thanks for looking,
Danny
