oil leak
Started by Spacemonkey1993, January 28, 2011, 04:23:58 PM
Spacemonkey1993
Hi.
im new to this forum and ive just bought a g40. Its all good and very quick but there is one thing i dont understand. as you can see in the pictures there is a blue tube where the air from the supercharger comes out, and from seeing other pictures it seems to be going back into the top of the engine block. But i have also seen the same set up i have where it is just 'hanging out'. the problem i have is that when i put my foot down small amounts of oil come out of the pipe. is this normal and should i have some sort of filter on the end of it? please help me!  ???
cheers.
hi,
that's the boost return pipe, quite a common modification to open it up like that.
However, the bad news is that oil coming out of there is more than likely to be the charger seals leaking meaning that it's time for a charger service/rebuild.  Talk to PPP about this.
Spacemonkey1993
Quote from: hayesey on January 28, 2011, 05:01:34 PM
hi,
Thanks very much. Sounds expensive?
