PSD Eaton Supercharger Pulley Dimensions
Started by picklesg40, December 16, 2010, 02:27:58 PM
picklesg40
hey guys
basicaly ive got near enough everything to finish my eaton conversion
bar the supercharger pulley, and a few other little bits
with the pulley being near impossible to get hold of, im going to have to get one made up, presumably CNC'd?
if anyone knows the dimensions and how many teeth etc these pulleys have id really appreciate them
also any other info on them too
poloeatonm45
psd made 2 types of pullys a 24 toothed one and another larger one but cant remember how many teeth it had. i have a 24 toothed one but its really worn so if you can find somewhere that will make you some i,ll take a couple from you as spares
steven
picklesg40
ok cool
so its 24 teeth
gathering its a 65mm pulley?
any one know how wide?
or any other dimensions
yeah ill see what i can do once ive got all the measurements etc, and what kind of price i could come up with
Justin14100
I've been looking into replicating these for a while now the 24 tooth should have a 28 tooth alternator and a 48 tooth crank pulley
youngprodigys
PSD made 2 types - which are we talking about. the custom toothed pulley - or the one with the sleeved adapter to fit a standard eaton
poloeatonm45
not sure really that is just what i,ve picked up reading the forum all i know is mine is the 24tooth one i think the belt is 20mm wide so the pully needsto be a lil wider, next time im at home i,ll measure the pully and getback too you. i would love a spare as mine is really worn and i really dont want to go back to ribbed belt set up as i had to run with it that tight the belt got hot and only lasted about 150 mile lol
steve
picklesg40
im talking about the one with the sleeved adapter
ill also check the amount of teeth on my other pulleys
Oily Fingers
i have a psd pulley on my eaton project, i'm going down the unit tomorow, i'll take a few measurements and count whats whats for you.
oily fingers - thats a custom one.
PSD eaton chargers are shorter.
Oh and they ahve a key way made in the shaft too - which normal eatons dont
poloeatonm45
ah thats right pete my pully does have a key way infact was it you i bought my worn one off?
Oily Fingers
Quote from: PeteG40 on December 20, 2010, 08:58:18 PM
hahaah good point.
