spark plugs - what do you run, and where from
Started by grungeisdead, December 13, 2010, 01:18:23 PM
grungeisdead
0.8mm Chris
http://www.ngkpartfinder.co.uk/car_commercial_extra.php?id=3735
they should be set from factory, but always worth checking, takes seconds and your car will thank you!
.8mm is a good starting point, if you're putting a large amount of load on your ingition system (high boost levels, rich afr, nitrous etc) then you can start to close them up, bear in mind cold start will be abit rougher as a result.
Yoof what does that do to the plug when you close the gap on the plug?
xandyx
you guys really buy the plugs too cheap! here in Portugal you pay 40£ for each w5/w4. i recently bought a set of 4for an amazing price of 90£. I'm sure gonna order some plugs from uk.
Wow! that is a big difference there! You should get them from uk or someone from the forum send them out to you?
