Replace rubber engine/gear box mounts
Started by Jezza-7, November 14, 2010, 01:21:53 PM
What is the best way to remove the rubber mounts??
And then how to put them in? Was wondering if there is anything i have to watch out for?
Easy enough to do really, pride the old one out with a screwdriver.  Press the new one in with a vice using some wd40 to lube it up.
With the engine/gearbox mount, is there a reason why the spacer is that big? Does it need to be that big? Just im replacing mine with a stainless washer thats a little bit smaller.
dub-disaster
I noticed this as I had to buy and old mount as I lost the inner bush, the hole in the inner bush pretty big for saying only a m12 bolt goes through it I did wonder why aswell.
Ok, tried using the vice method and no luck. Will it be harder for polyureathene mounts to go in?
dub-disaster
I just did mine pressed it out with the hydraluic press  at work I can do yours of you want mate let me know. Cheers for the heads up about the radiators and intercoolers I will go n see what thy can do for me  where abouts in town are they ?
They are in the lynx trading estate. Byrmpton way, http://maps.google.co.uk/maps?hl=en&expIds=17050,25657,26486,26490,27213,27816&xhr=t&cp=12&um=1&ie=UTF-8&q=raysons+radiators+yeovil&fb=1&gl=uk&hq=raysons+radiators&hnear=Yeovil&cid=0,0,10438856500747689113&ei=Yjf_TLn6Nsq5hAeolIXpCw&sa=X&oi=local_result&ct=image&resnum=4&sqi=2&ved=0CDUQnwIwAw
That should make it easier.
They supply Radiators, Condensers, Driers, Compressors,Pag Oils, A/C Gas, Heaters, Visco Fans, Visco Clutches, Oil Coolers, Intercoolers, Head Lamps, Rear Lamps, Fuel tanks, Number Plates. The radiators are ally as well and are really light.
Im going home for 5 weeks now mate but when im back i will drop them off for you as that will help me loads!
dub-disaster
No problem man give me a shout when your back :)
