removing the pulley
Started by g40Ross, November 20, 2010, 04:39:30 PM
g40Ross
can anyone give me some advice on how to remove the pulley from my charger as its dead and its time for a swap?
thanks in advance
Ross
dannyb.G40
Airgun is probably the best, I've always used a pair of stilsons or a vice but be careful not to damage the pulley.
g40Ross
it just turns the pulley when i do that is it just notis there anything i can do to stop the pulley turning?
Ross
put an old belt around the pulley and clamp it. Then undo it.
newt
Quote from: Jezza-7 on November 20, 2010, 06:11:32 PM
you running tooth belt or v belts as if your on v belts and they are a little worn  you will mark the pulley
water pump pliers/stilsons with a iece of leather /rubber will work , used this technique many a time
g40Ross
woody02
got mine off with a cordless impact gun, worked ok, or nip the charger to a local garage and see if they will loosen it for you
Nick_S
Lock off the turning with stilsons or large chain whip filter remover.
toothies, i tend to use a chain whip with old belt on it to stop damage
