fitting new ppp manifold,charger belt tension?
Started by gti jack, July 17, 2010, 06:54:33 PM
gti jack
i started to fit my new manifold to the g40 and wasnt exspecting it to turn into  a pig of a job,so i have loosend the charger belts to make room for the old manifold to come off,im in the process of putting it all back to getther and im just wondering hoe tight the belts should be and if there is a way to get them tight as i only loosend them by undoing a bolt lol, how tight should they be and how to go about doing it?
jack.
If you look at the charger end plate there's a square hole which is just over 1/2" stick a breaker bar in there and push towards the rear of the car, then nip the bolt up.
Easier with 2 people but you can do it with 1 :)
JIMMYP
tightness i'd say so u have a few mill of deflection thats how ive done mine and dont get no slip
NeilG40
According to the haynes manual
New belt   135nm     100lbf ft
Old belt     80nm      59lbf ft
JIMMYP
