charger not working!
Started by g40Ross, June 08, 2010, 10:08:08 PM
g40Ross
my charger has just stopped working not long had a rebuild. i can hear the charger spinning but just no pull!
what could this problem be!
please help!
Ross
boost leak or the boost return valve not closing perhaps?  Any new noises or anything?
g40Ross
not that iv noticed no! were is the boost return valve located? iv read in places before about a boost return mod, what does that entail?
Ross
could just be  yr throttle cable not tight!
g40Ross
Quote from: PeteG40 on June 08, 2010, 10:45:38 PM
infact you could well be right there, the screw that adjusts the idle has come out! would that make the cale loose?
Ross
g40chris
my cable was loose in the past as the small metal clip had come off just before it goes into the bulkhead. had same symptoms. hope its just that easy fix then. or your boost hose may have lossened off the intercooler. mine done this in the past and you could still hear charger but i was getting nowhere
boost return valve is on top of the throttle body.  Probably best to remove the boost return pipe from it and then press the accelerator with the engine turned off while a mate looks at the BRV to see if it closes fully when pressing the pedal right down.  If not then it's probable that the accelerator cable has slipped or is knackered.
g40Ross
its really pissing me off! i know people who can source problems and fix cars, but they are just so unreliable. so i just dont bother asking!! it looks like i may have to take it to my local vw specialist! and that could cost me an arm and a leg! i just want my power back, its no fun anymore! >:(
tdh-syorks
Mine did this, it was the spring clip which holds tension to the throttle cable which came off. When the accelerator was being pressed the outer cable was moving too. New clip and it was sorted.
g40Ross
got my charger sorted! my inter cooler pipe had some how split! my car is now fun again!
g40Ross
Quote from: cheys03 on June 15, 2010, 01:05:48 PM
Was this the split http://www.polog40.co.uk/forum/index.php/topic,4759.msg34628.html#msg34628 ?
or was it somewhere else?
no that wasnt it it was the actual charger to intercooler piping! at the bottom! no idea how it split!
cheys03
Ah cool. Glad you got it sorted, thanks for the info
Puncharado
Quote from: g40Ross on June 15, 2010, 09:09:49 PM
They just split due to age, coping with boost and flexing. Not at all unusual.
