py lump in mk2
Started by goosyganger, April 29, 2010, 01:31:25 PM
goosyganger
Im thinking about putting my g40 into a mk2 loon that I found. but someone pointed out to me that it indeed doesnt have a servo. So if i put the lump into it and blank off the end of the big black vacuum pipe that goes into the servo in a mk3, what do I do with the small white vacuum lines that go into the fuel pressure reg and ecu map sensor?? can I leave them attached to that big pipe still because they will still get a vacuum from it? or do I need to get a vacuum feed from elsewhere??
thanks
just block the pipe up higher up than the take offs for those two small vac pipes and then leave them connected.
goosyganger
Ow it's a simple as that? I thought that with the pipe blocked up at the end it wouldn't work effectivly. But if all I have to do it blank it and leave the other lines attached then that's cool. No need to panic :D. Thanks heyesey
